the mower is a rally 20'' with a 9s502 briggs and stratton 3.5 horse engine and the pulsa-prime carb only ran off the prime and i rebuilt it and it still did the same thing so i put an old carb off of an older mower and it ran great for a short time but when halfway through cutting the grass smoke came out of the pcv and it would only run on half throttle and the engine would bog down then it would only run if i choked it all the way and pulled it alot of times when i took the oil out it came out brown grey and chunky. so whats the problem how do i fix it
