I have an Scotts S1742 riding lawn mower with a Briggs Intek 17hp OHV that doesn't want to crank over. I installed a new battery with the correct cranking amps but still no luck. If I turn the flywheel by hand a couple of times it seems to free it up and starts up when I turn the key. After that it will I can turn it off and will will start fine again for a few days, but if I don't start the tractor for a week the engine won't start until I turn the flywheel by hand again.
Anyone have any ideas what could be going on?
I believe the Scotts 1742 is the same as John Deere Sabre 1742GS and has the Intek 17hp OHV Model 311777 Type 0143-E1.
Thanks
Thanks
