briggs and stratton
nut buster
does any one know what part number for a ignition coil to convert my vertical bgiggs from points to electronic
That part number will vary depending on what model of engine you. Get us the model number of the Briggs engine and then we can get you a part number for the ignition module
Well do you know what hp it is and if has an aluminum or iron cylinder block?
