briggs and stratton quantum
Andysp
Hi I have a rover lawnmower with this engine.After priming it starts first pull but then dies out.If I keep giving the primer bulb a few presses while its dieing out it will keep going and after a few minutes it will run without help.To restart I have to prime again but it will keep running.I have sent for new primer bulb, do you think this is definitely the problem or could it be something else?
