Briggs and Stratton 475 Series
bigdee
I have an Edger with a B&S 475 Series Engine 148cc and no carburetor. Can someone give me a part number for the required carburetor? Derek
Will need the actual model number from the engine to assist. Depending on engine could be in various locations. From the area of the blower housing above the spark plug, to the flap above the muffler, to stamped into the block.
bigdee
The engine is a Model# 093302, which calls for a Carburetor#795533. Unfortunately, all my research shows this carburetor is discontinued. Is there a cross match carburetor by chance?
Did you get any answers on this? I right now have the same piece of equipment in front of me. I do have a carb but it leaks. I replaced o ring, float, needle valve and seat, I just want a new carb at this point. I too have done lots of looking and have come up with a $50 replacement or discontinued.
