briggs and stratton 19.5 hp engine wont turn over.
rolltide84
tried jumping my craftsman mower with a 19.5 hp engine and fried the solenoid. replaced the solenoid and now when i try to start it, it will turn maybe half a turn, making a god awful noise and then stop. then if i turn the flywheel back to where it is free, turn the key and get the same result. any suggestions????:confused2:
ced
Your valve clearance is likely out of adjustment. There are several threads to adjust them on this site. It is an easy fix but I found mine needed tighter intake clearances than where called for.
rolltide84
thank you sir! i will try that! what causes that, by the way. I had been cranking it over quite a bit cuz it wasnt starting. after some maintenance, i ran into this problem and dont even know if its going to run....
I suggest you check the bendix drive on the starter. Could have the teeth broken off.
rolltide84
Rivets, if that was the problem, what would the solution be? Buy an entire new starter or can you replace the bendix itself?
rolltide84
Thanks for all the suggestions too, fellas. I havent tried any of them out yet. i married into a big family and have to spend this weekend travelling. but i really appreciate the suggested remedies. i will let ya know how they go.
You can just replace the bendix, much cheap than a new starter, even if you need a mechanic do it.
