It burns a lot of gas and a little black smoke. I cleaned the fixed jet, changed the plug, and checked the fuel pump. there isn't any blow by at the intake manifold gasket. We did shorten one valve stem since it wouldn't close all the way. Aside from taking the carb off and soaking it in carb cleaner, not sure what to do. The air cleaner is good too. Thanks.
