Briggs 1350 Snow Engine
dhammon
Briggs 1350 Snow engine.... what is the bolt for the end of the crank to hold pulleys on? What size?
Need the model and serial numbers from the engine to help you. I hate guessing.
Well need the engine model and spec (type) numbers to look up the crankshaft.
I thinking it is 3/8-24 but like Rivets like to be sure.
3 / 8 = .375
No spec given on the depth of the hole.
