Briggs 12.5 HP RPM settings
jakesmurray
What should the run and idle rpm settings be for a Briggs and Stratton 12.5 hp I/C Quiet engine? The Model is 286707, the type is 0420 01, and the code is 92050831. Thanks for the help!
I'll take a stab at 1000 RPM for idle, and 3200 to 3400 for full throttle, no load.:smile:
Ok, I did a little research, and it said 3300 for run with no load. I probably set it for 1000 idle and 3300 run. Thanks for the help!
