Blower wont turn off
Cdy291
Often times when I flip the power switch on my craftsman blower it refuses to die. It may change sounds a little but just keeps chugging along. If I turn it off and on like 10- 15 times it may finally die but some times I just have to pull the spark plug. Any ideas on what could cause this? Its like it dieseling.
Could be a bad on/off switch, or loose connection at the switch or ignition module
the carbon could but look at your plug and look in the hole you can see if their is enough carbon to cause it to diesel but sounds like a shorted switch
