Blades turn when mower starts
Mr zip
My husqvarna yth2448 runs the blades when mower starts. I have replaced the switch that starts and stops the blades
But problem still exists. Any help with this problem would be appreciated.
:welcome:
There is a little bit more to this story.
If you want help you need to tell all.
This did not happen because the gremlins snuck into your shed overnight and swapped wires around.
So what was done to the mower before it started to do this ?
