Blade Tip Speed
Ric
Wondering about the difference in Blade tip speed between the residential self propelled push mower and a commercial. Like the difference between the Toro Time master and the Turf master, or the toro 21" personal Pace. Anyone know or have any ideas?
Back to teaching mode.
All you need to know is the length of the blade and the RPM's of the motor.
Blade length multiplied by Pi. That gives you circumference. Now multiply that times your engines RPM's and divide by twelve.
If I'm not mistaken, the pulley that drives the blades should be the same size as the one on the crankshaft of most mowers. This gives your blade the same rpms as your motor. I could be wrong about that. Maybe some engineer on here could tell you more about that I don't know.
Example:
Blade length = 18"x Pi (3.14)=56.52
Now all you have to do is multiply that by your RPM's (3650)
56.52 x 3650 = 206,298
Now divide that by 12 ie; 206,298/ 12= 17,191.5 ft/min
I think that's it.
The magic number that the industry used was 19,000 ft/min back around 2000, may have changed. To put it another way, blade tip speed will be between 175-215 mph depending on engine RPM's.
mowerman05
just purchased a exmark 30 with a blade tip speed of approx 18500 fps
Ric
You just purchased the exmark 30" I just piked up the Toro Turfmaster today. :thumbsup: Toro Turfmaster 005.jpg
Example:
I think that's it.
Thats what I have always heard 19,000 ft/min.
