Blade spindle look right?
roneg
I just started to change the blades on my 54" Husqvarna riding mower. Seems to me the star shaped shaft is too short doesn't seem to even catch the blade. Is this normal? I'll try to attach a pic.
I have done some light grinding/repair work on the starts in some cases, but that star looks too far gone, and will require a replacement shaft. Just don't attempt to remove the spindle housing from the deck unless you want to replace the entire spindle because the mounting bolts will break off if you attempt to remove them.
Thanks ILENGINE. Appreciate the spindle housing weakness. I have got that info. Prev. From research prior. Seems a desighn flaw for sure!
Hello R.,
Replace the spindles and install new blades that have to correct star pattern. I typically get deck spindle and blade kit off of eBay and have had no issues.
Here is an example, but make sure it is correct for your mower deck:
The thread shoulders on the blade holding bolt look pretty bad too. like the blade has been rotating on them. I'd consider replacing that too.
