Blade sharpening
BHLC
Curious to see what other methods people are using to sharpen their blades
exotion
I vice grip mine to my work bench and use a angle grinder to sharpen. Balance has never been an issue I test for vibration and if it is then I use the nail in wall technique to find out which side is heavier and sharpen that side a little bit more I DO NOT GRIND OFF THE WING
mowerman05
bought a rotary blade grinder off e bay, major expense but do not have to wait for anyone. Sharp when I want them:smile:
jekjr
I have a blade grinder that I bought off of e bay that I use some and there is a guy right up the road that sharpens saws that grinds and balances them for $10 a set that I use some time as well.
Carscw
I use a bench grinder and double check balance first with the nail on the wall and then on the cone
(( racing is the only sport that you need two balls ))
BHLC
I have a bench grinder and a hand grinder, I was thinking of getting a blade grinder but there's a guy around here that'll do a set of 3 for $15. He sharpens better than original manufacturer.
Ric
I prefer a hand grinder to sharpen blades. I hope you do realize that the nail in the wall thing is a total myth? I can't believe that people by into a myth like that. There is No way possible to balance something with out finding its center, that's a proven fact and in order to balance a mower blade you have to find the center of rotation.
mowerman05
I have tryed to balance on a nail and then check with a cone balancer, such a big difference. just a little out of balance and my mower seems to shake all over, maybe its just me. Balance every time I sharpen them
BHLC
My blades get balanced using the finger tip method!
Step 1- sharpen blade
Step 2- extend arm
Step 3- raise middle finger
Step 4- place hole of blade on finger tip
Step 5- laugh like an S.O.B watching your employee try to pull this balancing method off!!
motoman
This forum has a lot of stuff on blade sharpening. Hit the search button and enjoy a favorite topic (next to oil).
