Blade Sharpening Honda 3 in 1 mower
girlsrule
My husband removed the blades on my Honda Mower and put them back on - my mower does not seem to mow as level as it did before - before it mowed where my lawn looked like carpet - perfect - it's driving me crazy? Is there a trick to putting the blades back on - or does it have to do with how they are sharpened?
BlazNT
Check to see if it is upside down.
BlazNT
I did not see your private message till today. Sorry. The blades can be put on upside down. Meaning the cutting edge is on top not bottom. The edge being that was is not the real problme the lift the blades create is now gone when updide down. It blowes the grass down instead of pulling it up.
Second thing to check for is the blade not seated on the spendal correctly. If this is the case the blade will wobble when mowing and give a really bad cut.
