Blade on wright walk behind instantly come on when strated
Zrafferty
I have a wright valkery which been trying to figure out an issue.
The electric clutch turns on as soon as it gets started and will not turn off.
I have even tried removing the pto switch with same result I do not see any wires damaged or anything along them lines any thoughts ?
I have the operator present switch permenantly pressed which I have 2 other mowers which have same thing done so I can lock levers without setting mower into neutral.
Any ideas would be appreciated thanks
