blade guide
jd335
I am trying to find a guide if thats what it's called to put on my grinder to make sure when i sharpen my mower blades i get them all sharpen @ the same angle does anyone know where i can find them
My bench grinder came with brackets angled to properly sharpen blades. I doubt there is such a thing as a generic attachment that would fit all bench grinders since they come in all different shapes and sizes. Your best bet is probably to research your specific make/model online and see what's available.
You can clamp or otherwise attach a metal or wood stop on your bench grinder that will let you slide a blade across the face of the wheel... It will stop the blade angle the same place so when doing the same width blades it will always hold the same angle on the blade thickness.. KennyV
