A fly mower is a mower with out wheels also called a hover mower. It rides on a pocket of air mad by a fan. Most have trimmer line in place of a blade. Most the time they are used on a golf course around the bunkers ( sand trap ) and on hills you stand up hill and swing it side to side
(( cowboy up and get over it ))
#5
GetTechnicalWithJd
Here are some photos of my Hover Mover to give you all an idea.
brianr: As for your problem, has your empellar perhaps cracked? This will stop the unit from hovering.
How do you start it? I know its electric, but it seems that on start-up, the blade / trimmer string would gouge up the lawn. I guess you must tip it up? Pretty interesting.
Thanks,
Bruce
Thanks,
Bruce
Hello , some mowers of this kind have a belt running from the motor back to the blade and fan ,if all you hear is the motor starting up and no hover action i would check your belt or see if your blade is tight , Gary :smile:
