Bigdog paint color
rt4x4
I know this is the Hustler forum, but since Bigdog is also made by Excell industries, I was wanting to know if anybody know which red would match Bigdog mowers.
mhavanti
If you know someone with a smart phone, download the paint match app, wash the mower in a non-wear spot, wax it to get the color to its actual color, then snap the color outdoors and that will give you something to take to an automotive paint shop. They can mix it for you and you'll be all set.
Good luck.
Hyme
The closest spray can I found to match is one called "gloss red pepper" that I found at Lowe's. I would add pictures of both the spray can and paint job but I'm not sure how. I don't see an option for adding pictures
7394
Look under your post area when you post, & you should see a rectangle button w/"Manage Attachments" Click & follow the prompts.
It's easy..
Hyme
Thanks for the tip! So the area I painted is up and to the left of the "60". Not a perfect match but it's close enough for me.
7394
:thumbsup: ................... Nice match up, I think you nailed it..
