gamecock66
- May 25, 2012
- 7
- 27
I have a 22hp OHV B&S engine on my 2005 Husqvarna lawn tractor. The battery stopped charging but it is a good battery and holds a charge when charged. I tested the volts on each side of the 2 wires coming out of the stator. I got a reading on the AC but barely anything on the DC. Does this indicate a bad stator? I pulled the flywheel and cleaned the stator contacts and am about to put it back together and try again. Is there a way to bench test a stator? If it is not the stator what else could it be? I can cut my whole yard as long as I charge the battery first but by the time I am about finished the battery has dropped enough to where the electric clutch will not stay engaged.
Ideas??
Thanks
Wade
Ideas??
Thanks
Wade
