On the Bronco, there should be no load to the battery when the key is not in. Unless they changed the design, I also have the Bronco and I never disconnect the battery over the winters and there is no measurable electric current coming out of the battery terminal when not in use. This is different from a car where many electronic devices are loading the battery (ie. remote controlled door locks, alarm, clock, radio etc).
