Bagger for 1995 SR1433KVE w/ Kawasaki engine
wormst
Just bought a 1995 SR1433KVE...runs well as just got a new carb (or carb kit) and fuel lines, etc. Two questions...1. Where do I find a bagger (preferably twin bagger) for the 1995? I can find ones online for newer models, but don't see one for the older models. 2. Mine has a Kawasaki engine...can't find anything in the manual or online about Kawasaki engines on these RERs. Anyone have any info on this? Thanks.
TW
I don't see what the type of engine would matter unless it is mounted in an odd way or the exhaust is exiting differently than the stock exhaust.
Even with the stock engine and exhaust you need a heat shield to deflect the heat from the bag and or tube.
Do you have pictures of the rear of your mower?
Should have separated the 2 issues. I'm looking for a bagger, and I'm looking for info on the Kawasaki engine...the two having nothing to do w/ each other. The exhaust exits the same direction, though it is larger and rectangular as opposed to the small circular ones I've seen. I don't have a picture as I took the mower to S. GA. this weekend, but will post one if I can get my family to take one.
