Export thread
Bad Boy with 26 hp Kohler engine starts and runs but shuts down hot,,Possible cause
#1
R
r goekler
Replaced engine in Badboy 30 hrs ago with new engine. Has started to shut down ,very hot, possible causes??????
#2
S
shiftsuper175607
Mowing with engine not at full throttle
Valves are out of adjustment
#3
L
Luffydog
Welcome to the site. Dirt build up dust grass etc under the shroud and around the cooling fins of the head can be your cause of the extra heat. How old is your bad boy unit. If it has two tanks check for fuel flow from each tank out from the fuel filter one at a time. Then remove the fuel filter and look at the fuel line there is plastic shielding in the replace fuel line and recheck fuel flow after replacing. The plastic breaks down and blocks the fuel from flowing like it should at times but not always. Might also have a lean fuel condition in the carb that might be causing your extra heat as well.
