bad boy mower are not good don't buy them they fall apart
Big Chuck
bad boys mower suck they fall apart DON'T BUY THEM all my baffles fell off the weld dose not penetrate the baffle in time after warranty over then they fall off
just don't but a bad boy mower
I could of told you this before you got one. Just another company cashing in on over priced mowers that us stupid American's keep buying.
Well it one here that the customer have broken three brake cable as they were so tight you play a tune on them or the PTO clutch that the deck braking system falls off. That particular clutch BB stop using.
Or a Gravely where to deck baffles mounting points breaks off due all the flexing. Customer done had them welded but whoever did it did poor job and they also didn't re-enforced those areas. Not my place to warranty someone else workmanship.
Or the customer that brought a JD X350 that keeps throwing the deck belt and JD hasn't figure what causing yet. That customer said I would be getting it when the warranty is up.
surprisingly a worn brake shoe on some units can cause it.
As to the OP, since SARS2/Covid, when so many hard working people retired out, the quality of everything has suffered. Inflation came in during the last administration too in the worst way as they just spent and spent, (although half the US will deny it still), so manufacturers had to face selling at substantially higher prices - and lower sales volume because of it, or find ways to cut costs. The cutting costs has turned a lot of things into crap. We see it ALL the time. It is not manufacturer specfic although some are worse than others.
Beside nearly all deck welds on any mower is only done on side of the joints. This allows the joints to flex and break over time. Where when I repair broken deck they get welded on all sides.
