Export thread
B&S Quantum x50
#1
S
southerndreamer
Just bought this machine which hasn't been used for approximately 7 years. I have changed the oil, checked the filter and plug and it runs well for a few minutes then dies. If I give four or five squeezes on the fuel button it will start again easily but only run for a few minutes again. Suspect fuel supply or dirt in carb but have no details of how to strip and check. I have checked B&S web site and entered the model number but can't find any useful details. Any help much appreciated.
#2
Boobala
Boobala
NOW, .. we need your engine's numbers, see engine info in example.....
GET INFO.JPG .....click to enlarge
#3
S
southerndreamer
View attachment 35593 .....click to enlarge
OK thanks for your reply. My numbers are: 12f802 0906--02 97060259
Hope this helps
S
#4
B
http://outdoorpowerinfo.com/
Click on the repairs index button then the Briggs carbs.
There are a couple that might be yours as there were a few carbs fitted to the 1200000 series engines .
So worst come to worst you might end up looking at a few different set of instructions.
If you have the primer with the hole in the middle you will need to replace the gasket between the carb & the air filter and when it goes together make sure the nuts are tightened evenly or it will leak air & not prime.
#5
Boudreaux In Eunice La.
Maybe your fuel line is flapping on the inside of it.......... A good carb clean could be in order... Setting that long the seat could be swollen from Ethonal gas also ........
If it sets for a couple minutes when it dies, the bowl has time to fill back up to run again for a few more minutes...
Hope this helps Mon Ami ~!~!
#6
S
southerndreamer
Many thanks for your help guys. I have ordered a recon kit and will use the info supplied to strip it down and replace everything. Watch this space.
