B & S 5hp
richram
Hello Im having problems with a 5hp B&S the primer was leaking I replaced it, and the carb gasket open the bowl cleaned and the check the pin in the carb put back and it tries to start but wont what can I look for thanks for any help Rich
If it was running fine except for the leaking bulb, go over your repair job, I've misaligned gaskets, left bolts out almost everything else. Check it over closely.
