B & S 305 leaking fuel
trialskid
Hello
I have a snowblower that is leaking fuel from this hose. Anyone have any idea what this is and how to repair it? Thanks!
The tube is the breater tube to vent the crank case.
If you have fuel leaking out of it then the float valve in the carb is not cutting off the fuel and your sump is full of fuel.
Check the oil level. it will probably be very high.
Drain the sump, clean & rebuild the carb
