B&S 24 hp zero turn z560 wont run
Hoppe
Ive changed fuel, fuel filter, fuel pump already. Plugs 6 months old, look good. Was running and just stopped. Has oil. I sprayed carb cleaner in it, let it set for an hour. It started and then shut down again. Im wondering if i let sea foam set in intake will help or if i have to pull carb. Any help much appreciated
Stopped like you turned it off or stopped like you ran out of fuel ?
