b and s 42a707
shatton1980
just bought a mower from a guy who said it was running earlier this year, it has a briggs and straton 42a707 in it. i replaced the battery and starter, did an oil change and cleaned out the fuel tank and changed the fuel filter. it doesn't even make a sound when i go to crank it. what things should i look for to troubleshoot this? im not exactly sure where to start.
Mikel1
When you say it doesn't make a sound when you crank it, do you mean it will not turn over or start up? If you mean it will not start up then check for spark & fuel. If you haven't already replaced the spark plug then I would replace it. I would start with those first if your certain both of those are good then move on to checking compression.
Hi Shatton!
Sorry you're having trouble with your mower, lets see if I can help. You're off to a good start already, next you will want to check and clean the carburetor. You might also check the valves and the valve seats. Make sure the seats are not backing out. I hope this helps! You can also check us out on Facebook at https://www.facebook.com/BriggsandStratton for more help or troubleshooting!
Let us know if you need any more help!
Carscw
On the solenoid there are 3 wires 2 big ones and a small one.
Makes sure you have 12 volts to the one coming from the battery.
Then check and see if you have 12 volts to the small wire while you hold the key in start.
Report back with what you find.
No need to buy anything or clean the carb yet.
Use this procedure to test your starting system. As Carscw said, don't start throwing money at it until you need to.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
