Hi, new here but certainly not new to working on my 10 year old Dixon 4515 ZTR. We use it a bit harder than a homeowner-grade mower probably should be used, but not crazy or abusive. The originaly Vanguard 16.5 (I think) threw the rod two years ago. I ordered and installed a 330000 Intek ELS 21 hp 540cc engine to replace it. Worked great with all the extra power, and in fact still runs great. But now in it's 3rd season the fuel pump got balky. I replaced the pump, figured out how they work after. Momentary crankcase vacuum I guess? Anyway, it is still having trouble. Runs/sounds good, but it starts fading under load, I can see in the filter that fuel supply is still the problem. The pressure for the pump comes from the dipstick tube. The tube seems well sealed top and bottom, no cracks in the hose. For grins I pulled the dipstick out and started the engine, oil came SPRAYING out the tube. This is not normal, I assume? Hard to believe my rings have already failed. Oil consumption is negligible. Any ideas? Thanks.
