Any one ever had problems with 48'' Husqvarna older model broke 3 deck belts with in 2hrs.has two new spindells .
watson
  • / Any one ever had problems with 48'' Husqvarna older model broke 3 deck belts with in 2hrs.has two new spindells .
Scrubcadet10
Moderator
Staff member
did you replace the spindles before or after the belts started breaking?
a022mil
Check to make sure your frame is not cracked, mine was, that is why My belts were not working, had to replace entire frame, that is one bad item about husguavara mowers.
We need to see the belt.
The damage to the belt will tell you why it is breaking.
Search " V belt failure guide " and you will find lots of charts from belt makers & mower makers to help you understand why your belts are failing .
Also post the unit model and serial numbers so we can see which unit you have.
watson
Scrubcadet10
Moderator
Staff member
So there was no issues BEFORE you installed the new spindles?
watson
Was used when i bought it so do not know the history ,was in need of carb & Manifold etc put more in than it was worth and still have issues.
mechanic mark
Are you using Husqvarna OEM replacement parts? Belts etc.?
