Export thread
all year cab?
#1
S
sss
Hi there i want to put a all year round cab on my mtd tractor it will have to be a pvc tubing frame as i cannot weld a metal one:frown: will this tipe of frame be strong enughto support the cab? if so what shuld i use for the sides? clear plastic ,fabric?
#2
B
Black Bart
Clear plastic would be like a green house it will be 140F in that thing.
AC big enough to cool that will take a lot of power engine will need swapped out for a bigger one.
I would build it so it could be removed real easy and use it only in cold weather.
#3
D
dhellinga
I'm planning something similar, but am making the frame from steel. I plan to use thin plexiglass for the windshield, and a coated polyester fabric on the roof. The rear of the cab will only be partially closed in to allow for ventilation. The sides will be removable, and I will use 20 gauge clear vynl for them.
