aeirns 12ytd
skidoo shawn
looking for help with this tractor. Its a aeirns ytd mid eightes 12 hp 3 speed trans. The high low range shifter connnection broke off. I took it all apart and welded the shifter linkage connection. Before this happen the tractor only had two gears, first and second with hi and lo. After I repair the linkage connection the tractor will not go into any other gear than first lo and reverse. No second gear or hi range. Anybody have any ideas?
Briana
Hello, I have moved your post to the Small Engine & Mower Repair Forum. You will have better luck finding assistance there. :wink:
Thanks for joining LawnMowerForum!!!
