The previous owner of my 721D replaced the transmission on one side of the mower last fall. As a result of that, or something else, if I push both control arms completely forward, on a level surface, the left side spins faster than the right side... is there a way to adjust one, the other or both, so that they run at the same speed? Or alternatively, can I or should I adjust the throw of one of the control arms so the two sides match speed? Thanks as always...
Geoff
			Geoff
