Adjust valves on briggs 19.5 hp engine m# 42E-707 2631-e1
Birddogtc
  • / Adjust valves on briggs 19.5 hp engine m# 42E-707 2631-e1
how do you adjust the valves on the style engine
You have to remove the valves from the engine, and grind the valve stems down to set the clearance. this is normally not done on flat head engines, are you having a problem with something.
Fish
https://www.google.com/webhp?source...espv=2&ie=UTF-8#q=adjusting valves b&s engine
Watch video's.
Object moved click.anyway
Information posted in #2 above by ILENGINE is incorrect.
This engine "is" an l-head twin.............
If he is having trouble getting the engine to "turn over", he should look at the starter top bushing for excessive wear, as well as
the whole starter in general, but moreover, he should de-carbon the combustion chamber as that is likely the root problem, as well
as replacing the air filter, which probably caused the excessive carbon buildup.
