Adding Transmission Fluid?
howaya
A few years ago I was given a Yard Machines (by MTD) Tractor, 2000 model 13AI607H118. Now that I have recently overhauled the mowing deck and for a change can actually HEAR other components while using the machine, I have come to notice a whirring sound in the rear end only when moving. I do not know if this sound is normal, but I wonder if this model has any way to drain and add fluid to the transmission. I am aware many LTs have sealed transmissions, but this machine appears built, in general, to a more durable standard. As such, I'd like to maintain it. If you think I should simply poke around a bit more, is there one side behind a wheel (other location) that I am more likely to find access? And, what type of fluid is appropriate?
Single speed differential uses 00 Grease. No way to change except disassembly of unit.It may be the bearings in the variable speed pulley or the idle pulley. Worth checking before condemning the transaxle.
hlw49
You would have to take it apart to add grease unless you drill a hole in the case. It uses bentonite grease. Bentonite grease is one of the best types of grease for industrial applications, they are high-quality, extreme pressure (EP), clay thickened grease developed for the lubrication of industrial equipment operating under heavy loads and at high temperatures.
Personally I am going to keep using the 00 Grease as the other grease used to dry out and no longer lube the intend gear train. Now the unit does to be fully seal to use it and not to depend the metal to metal case contact points as any grease will seep out. Be it the 00 or some other grease.
Star, I agree with you to a point. Problem is the 00 grease will not mix with Bentinite so to switch over to grease you will have to split the transmission, remove all the Bentinite and then replace with grease. From experience I can tell you this is a dirty and messy job.
Most times I got clean out all grease to get rid all metal shrapnel embedded in the grease. Of course that during rebuilds.
Auto Doc's
I recommend you replace the drive belt along with the stationary and idler pullies.
The single speed F/R transmission in these old riders were bullet proof. They used a light grease and not a pour in fluid.
howaya
Wow, thanks to all of you for your replies.
SterTech's comment, "It may be the bearings in the variable speed pulley or the idle pulley. Worth checking before condemning the transaxle" makes plenty of sense, but getting to them is just as difficult as the belts that run from them. I need to take another close look and contemplate replacement of the pulleys and belts myself or paying a shop to do it. I am pretty sure I already have all the necessary parts.
So far, I haven't found an ID tag on the transmission. I have inspected all sides except the bottom. The diagram that Rivets posted is helpful all the same as it shows what seems to be just a rudimentary system.
Many thanks to hlw49 for identifying the appropriate grease. Adding grease through a few small holes around the case appears possible but is likely far from the best approach. I assume opening the case is necessary but will not do that until after dealing with the pulleys and the belts.
Forest#2
All good info above.
What I would do since it's a new you you free machine.
and you want to work on it yourself
Download a owners manual and parts list. You can usually find them free.
The owners manual will usually have belt replacement and tips.
If that is the variator drive type tractor the two belts going to the variator have to be replaced as a matched pair and usually the first time is a learning curve experience.
If you later determine its the rear differential noisy and it's the single speed sealed type and you only hear it howl and growl at the higher speeds I just ignore such. Sometimes you can elevate the rear tires and the noise goes away or is reduced because the differential gears do not have a pull or coast load on them. A hint it's the differential howl is the noise will usually change pitch when going uphill or downhill and not mowing (no PTO operation) just riding the tractor.
because the gears are not spiral cut (just straight cut teeth) and some noise at high speeds is normal. They don't make much noise when new due to the heavy grease not displaced yet. They use bushing instead of bearings, so not geared for the long haul. Most of them just use grease (not oil) because no oil seals at the axles. (just bushing, not bearings and if lots of oil is added it WILL DRIP/run OUT the axles shafts. When I overhaul that type I just add 00 grease and dig out the benonite stuff but don't really get too concerned about it.
I have added about 1/2 cup 80-140 gear oil during assembly (just little bit)
You can find a free Tecumseh/Peerless transaxle download on-line to help ID y0urs and shows service data and part numbers
Not a fun job removing and opening up them single speed peerless.
I keep a eye and ear open for them to use as spares and parts.
(lots of parts on ebay after you determine what you need)
