9HP B&S Intek runs for two minutres then shuts off...
slt223
  • / 9HP B&S Intek runs for two minutres then shuts off...
This motor is in a Giant Vac blower. It stars with one pull when its cold, but when it get warm it shuts off and wont restart until it cools down again. What might be causing it to shut off?
MODEL # 205412
TYPE 0121E1
CODE 010705YD
Immediately after it dies check to see of you have spark. If not then most likely the ignition module is going bad. could also be a bad spark plug.
