Hello totally new to the lawn business/home
I acquired a srx95 a family member that bought it years ago but did not have the know how to fix it, so a couple days of work and 200$ later I had a running mower, but I got stuck when at operating temp under a load the carb will surge then stall out, I have to put the mower in neutral relieve the blades and full choke it just to start it up again. I have a feeling that whom ever owned it last really messed this one up, the deck lift was installed backwards and missing tension spring, the tires in the front were miss matched sizes. So I can only imagine what they did to the carb. Thanks for your time,
