928D2 Starting then stopping issue....
KdawgMO1
My grasshopper actually starts fine, then once started, if will die in about 2 seconds. Air and fuel are not and issue. Since it starts can I assume the safety switches and relay are not and issue. I suspect the fuel shut off solenoid.
Any Advise? Thank you for your reply!
NorthBama
not sure if your machine has the fuel solenoid that has the pull in coil and a holding coil. How many wires on the solenoid does it have
KdawgMO1
It should have three wires going to it according to the schematic. I will look at it on mower and verify...
NorthBama
ok a pull in coil and a holding coil check for voltage on the hold in coil
NorthBama
what year model do you have
