7000 seeies 26 hp won't start
johnrolf
Battery good, starter engages, solenoid ok, won't turn over. ??? 2 yr old Toro Titan
So I drove to town, got the dealers trailer, loaded it. IT STARTED AND HAS WORKED FINE!
Did our pushing the lawn mower get the piston to move over a tough spot? I'm 75, thought I've seen everything.
Sounds like a bad connection somewhere, when you push the mower , the piston is not moving so that's not the issue
