Grabbed a 61 bobcat with twin Briggs at an auction this past weekend. Nobody bid and I got it for what it is worth as scrap metal. It runs and cuts well. Fuel valve grommet leaks but can't seem to find anything else wrong with it. The one tank, the tank with the key on it has a 50:1 to stamped on it. No fuel in it, the other tank has the fuel I ran it on. 1000 hours on it. Will probably need some wear items, I've got a garage full of tools and some time. Any idea where I could get a manual for it, maybe that would explain the 50:1 stamping.
Does this thing need a mix?
Should both tanks get a mix?
Was it a cap from another machine and not relavent?
