52" scag turf tiger machine bogging down with blades operating
jvpatriot2015
  • / 52" scag turf tiger machine bogging down with blades operating
I have recently bought a 52" scag turf tiger whne i first engage the blades whne machine is cold it shuts the whole machine down once up in runnimng the machine lacks power while cutting. Any ideas thinking may need a new clutch thought i would check other advice before i spend the money on it. Thank you
motoman
Check spindles for free turning and blades for interference. Engine must product normal power (torque) when load is applied. Check health of engine (compression). Then fuel delivery. Does tractor also falter on hills or pulling a loaded trailer?
mechanic mark
Request Rejected click anyway, locate your numbers then manual, also check air filter for replacement, use OEM filter.
