327kw
if anybody has a grasshopper 327kw could you post a picture of the wiring harness plug and wires that connect the kawasaki engine to the grasshopper harness. the kawasaki plug has 6 wires and the grasshopper looks like it has 5. Thanks
Go to the Grasshopper site and on there you can request your owners manual to be emailed to you. That should help.
I have a grasshopper manual and a Kawasaki manual. I even called and spoke with grasshopper service and they helped as much as they could, but didn't have kawaskis informantion. Problem is the plug was melted/deteriated. the Kawasaki harness has 6 wires and the grasshopper harness only has 5 wires. just trying to figure out which wire should not get hooked up. You would think black to black, red to red etc but that wasn't correct. I was hoping somebody would have a picture so i could compare it to mine.
