311777-0209-e1 carb
thesabeans
which is the correct carb for this engine,in the parts diagram it shows three carbs for this engine 2 walbro and one nikki
the nikki is discontinued but that leaves the 2 walbro
mine is a walbro with the number 4993 stamped beside the idle speed adjustment screw and 2831 498888 stamped beside the air screw
the choices are 698782 or 698620 will either one work or which one do I need
thank youu
thank youu
I believe people will need make and exact model of engine to answer
