2448 loading up
cknoop
I have 2448 Husqvarna it is running rich. all started it was running on one cyl. one exh.. not as hot as other
I took carb off cleaned it put Kit in it- gaskets new orings at intake to head reassemble start sounds good engauge deck motor abought dies loading up black smoke pinch the fuil line till it stops sounds OK can drive it around all day as long as you dont enguage the deck i put in new foat plastic no adjusment for a split second it sounds like its going to go like hell but loads up
WHAT NEXT????? thanks for any info
