24 HP Intek Twin Backfiring through Carb and running rough
dcpropilot
  • / 24 HP Intek Twin Backfiring through Carb and running rough
Hi,
I tried a bunch of troubleshooting things but still can't find the problem. I have a new carb, new fuel lines, valves are good. It backfires through the carb. Taking the sparkplugs off one side at a time has no effect, leading me to thing to problem is common to both cylinders. My thought was that it could be a sheered flywheel key...nope. Next I tested the diodes. I tested both lines that lead to the armatures and they both are at 591 mV. Don't know if this is acceptable for determining if the diodes are good or need to be replaced. So far I am stumped.
motoman
If you adjust the valves , next time look closely at the valve guide positions. My 2009 did this with a pushed guide just before going to one cylinder.
LakeRat1
its possible its being caused by a Vacuum Leak, are all your gaskets on the intake in good shape?
Rat
