RE-bertsmobile1;227976
Thank you.
I have found the shaft size is the same. I have extended the fuel line. Cut the bolt holding the mower deck to the front part of the frame and "modified" the muffler with a hammer to clear the frame. I am working on the steering modification as the 22HP has an extended oil drain tube that interferes with the steering arm. If I can't easily modify the arm, I will remove the tube and replace it with the plug from the 13.5HP. The only other part is the throttle control.
The 22HP has a separate choke and throttle cable, the 13.5HP has only one cable that controls both. How do I modify the cables?
Thanks again.
