21hp Briggs And Stratton Intek
bmsdrfr
My 21 hp briggs intek engine won't start - I have installed a new battery, starter, adjusted the valves and cleaned the ground and put another ground cable on. It will try to start just like the battery is low, will not go past comprssion. Any Ideas?
The way you are explaining it... You need to adjust the valves....... If you take the plug out it will spin fine, but when you put it back in it under too much load...... The decrompression is not working becahse the valves are out of adjustment .........
Let us Know Mon Ami ~!~!
Try to adjust again like I said and if not then recheck all cables 2 times and clean well,,,, All cables not just positive....also the connection at the frame....
If none of that works then the de comp is laying in the bottom of your sump..... It broke off your cam......
Tinkerer200
Question is did you adjust them in the correct manor? Also, it is helpful if you post the engine model number as there is Intek 21 hp in both singles and twins and yes, it does make a difference.
Walt Conner
bmsdrfr
It is a single cylinder, and I will recheck the valve adjustment. Thanks
tom3
First thing I'd do is check the actual voltage at the starter when engaged. Need to have something above 10 volts. Maybe take out the spark plug and spin it over several times, make sure the cylinder is not loaded up with gas/oil etc.
Standard tests of the cranking circuit.
Before you start, pull the spark plug & try to rotate the engine by hand.
No use checking the electrics if you have a hydraulic lock, seized engine or jambed belt overloading the stater motor.
Assuming the engine turns freely.
I like to start from the starter motor and go backwards .
Do the following 5 tests, regardless of the results from an or all of them as there can be more than one problem and you want to isolate where the problem lies.
Elimination of individual parts is important so you know by the end, the battery, solenoid & heavy power circuits are all in good order.
1) try to jump the starter motor directly from your car or truck.
+ on the starter first then - to a good ground near the starter ( drain plug of lift hook are good )
Starter turns = starter good
2) do the same directly from the mowers battery
Starter turns = mower battery good
No turn = duff battery, recharge it & try again.
3) check for voltage ( + 12V ) at the solenoid trigger wire with the key in start position
3a) same with ground trigger wire ( 4 wire solenoid ) or body of solenoid ( 3 wire solenoid)
( I like to test V from the battery hot terminal to ground terminal rather than ohms as they give funny readings )
4) leave ground jumper in place ( from step 2 ) & try key start.
Starter turns = power connection good but ground connection suspect ( most common )
Confirm it by trying again, extra ground removed
5) Remove the trigger ( thin ) wire / wires from the solenoid.
Ground one on a 4 wire solenoid & bridge from the hot terminal to the other.
Starter cranks = solenoid good.
Solenoid is not polarity sensitive, BUT THE WIRING IS so make sure you remove the thin control wires.
Note a thinner wire on the hot terminal is not a control wire. It is the main power feed to the mower.
From here on things become very mower dependant as starting circuits are getting changed all the time.
Basically the power goes in a loop from the hot side of the solenoid ( saves wire, no other reason ) through the fuse to the B terminal on the key switch then to the PTO switch then to the parking brake switch then to the solenoid trigger switch , easy peasy after you grow the 3rd arm. Use a test lamp and follow the power.
However a lot of mowers with a 4 pole solenoid, run a secondary ground control circuit to the ground solenoid wire through the lap bars.
Then to stop this interfearing with the normal safety function of the ground kill, it goes to a relay with the ground as the switched connection.
These are a PIA as the + control wire to the relay comes from the power loop above and the ground side of the control comes via the normal cut out functions of the lap bars.
Be very careful because if you have a system like this and accidentally send 12V down the ground loop you can fry the magnetos on some circuits.nd from the grounding bolt to one of the starter mounting bolts & paint over both with liquid electrical tape.
