2135 loose connection at the PTO clutch
packardv8
Recently, my 2135 PTO clutch has been randomly disengaging. I have done away with the OEM switch and rewired with a HD Off-On, so it's not the switch. The workaround for the past couple of weeks has been to open the hood and wiggle the wiring connector at the clutch. Somehow, there is a less-than perfect electrical connection in the wires, connector or PTO. I pulled the connector and cleaned the contacts with spray cleaner, but problem is still there.
Anyone else had a loose connection in the PTO wiring? There's nothing to see externally. If I pull the PTO clutch and disassemble it, can I get to the wiring?
jack vines
Fish
Is the clutch adjustable?
Fish
Post the numbers off of the tag under the seat...
mechanic mark
You need to adjust air gap at clutch. Owners manual has instructions or if you prefer go to tractor manufacturer and enter model number.
packardv8
This is a 1990s 2135 Cub Cadet with a 13.0hp single cylinder Kohler engine and hydrostatic transmission.
The cheesy stick-on adhesive tag under the seat is long gone. Are there numbers anywhere else which would mean anything to you?
Not by any external means I can see. I know some of the older clutches have three external bolts. This clutch is a solid canister held on by a center bolt and a side torque stud.
Heat may be affecting the wires. I'm considering a heat shielding for them.
jack vines
mechanic mark
packardv8
PTO clutch is not adjustable,
Thanks for knowing your stuff, for the links and for confirming what I pretty much already knew - that the PTO clutch is worn, not adjustable and probably due for a $250 replacement.
jack vines
mechanic mark
Fish
Well you get a "MR." Jack Vines........
packardv8
Re: 2135 loose connection at the PTO clutch - SOLVED
Yes, the PTO clutch is eventually going to need replacement.
No, it's not dead yet.
Over the years, all the original wiring and switches have failed, one after another. Replacing the ignition switch and PTO switch with quality aftermarket, removing the reverse shut off, brake-start and seat switches, the only remaining piece of OEM wiring on the machine failed.
The PTO would randomly disengage. Sometimes cycling the PTO switch would restart it. Tracing it down, I would have to open the hood and wiggle the connector at the PTO. At first, I thought the short must be inside the PTO, because the external wires and connector tested fine for continuity. After cursing at it for a month, I just cut off the plastic connector and crimped on two new female spade connectors. Problem solved in five minutes at no cost.
jack vines
