21 horse briggs and stratton (intek) White rider.
cnulph
I replaced the stator, flywheel, and plugs. Still have intermittent spark, good hot spark for a bit than no spark at all. What could it be? 99 white ride on 407777 type 0128 EI
try changing the ignition module. the stator, and the magnets under the flywheel don't have anything to do with spark
Fish
It sounds like you are way off one way or the other.... You need to post model/type/code numbers, and all of the correct history
behind this issue....
cnulph
1998 white ride on eng#407777 type-0128ei
